Tk-App Documentation
Can I ‘override’ the default Documentation and Help & Support links for a tk-app?
I want the links to point to an internal Wiki not the Integrations User Guide/Shotgun Help Center.
tk-app_docs
I thought I remember seeing this somewhere but I can’t seem to find it now.
Daniel
Hey Daniel!
It’s not exposed as a setting, but if you’re writing your own app, there’s a support_url property on the AppDescriptor object that you can set.
Some links and things:
  • I don’t see any instances in our own apps where it’s being overridden, otherwise I’d share an example here :slight_smile:
  • Finally, I’ll point out that the tk-multi-publish2 app does things a bit differently – there is a configuration setting called help_url.
    Here it is in the app’s manifest:
and it’s used here:
Nope. That does it for now.
Added both to info.yml and working great!
documentation_url: “http://www.documentation.site
support_url: “http://www.support.site
Thanks again,
Daniel
