Task Durations Working In Reverse?
Is anyone else having problems with task start date, duration auto-populating in reverse?
I sorted these tasks and applied dependencies start-finish. I set the start date on the top task and then applied a duration of 1 day to every task. But the start date for the downstream tasks applied in reverse with every downstream task starting the day BEFORE.
Hi DJ!
  • Finish-to-Start indicates that the second task in the chain can’t begin until the first task finishes.
  • Start-to-Finish is the opposite, so when the second task in the chain finishes, the first task starts.
Finish-to-Start is the most commonly used dependency method and is likely what you’re looking for. To make the correction to your tasks, select the tasks and right-click > Dependencies > Finish-to-Start. This should fix the issue!
Does anyone have a good use case for when start-to-finish would ever be used? Is it simply about how the task order is interpreted regarding top-to-bottom (finish-to-start) or bottom to top (start-to-finish) ?
