I have a question about the entity file.
File entity url is changing along time.
When I use this url in a note whith the markdown method, , the link is lost even if I used the attach Url from the SG UI inside Note.
Maybe it’s not a correct way to work.
The basic idea is to have the visual attachment link to correct thread.
Because when a note is already created with multiple reply you can not attach an image to an older thread. The basic idea is to have the description followed by image for each thread. It a production constraint, and i understand you idea for me it’s the right workflow but it’s not a way of work for everybody.
When you reply to a note, you can attach an image.
But if I want to edit my thread create the 5 january, I can’t attach an idead.
I can’t attach an image and link the attach file to this thread
