Setting environment variables
Hi all,
I’d like to set project/scene/shot environment variables when launching apps from the shotgun app launcher.
I think this is pretty straight forward to do but I’ve had a browse around the docs as well google searching but I’m none the wiser.
Could someone point me in the right direction on how to achieve this?
Steve
Hi Steve –
The tk-multi-launchapp is the app that handles the launching of software from Desktop, Shotgun, or Create. The app has a hook called before_app_launch, which, as you might guess from the name, runs just before it launches software, and is often used to set the environment before launching.
Take a look at the hook here in github.
You can see that there’s even a commented out example of setting an environment variable in the default hook.
If you’re not familiar with the process of taking over hooks, there’s a very concise walk-through in this post – let me know if you hit any snags, and I can go into more details.
Thanks Tannaz, this looks like just what I was looking for
:slight_smile:
also found this link to the python Shotgun python api. Happy days!!
Hi Tannaz,
Would you mind giving me some direction?
The main thing Im trying to do is to set an ocio environment variable with a path to the current project’s ocio config. I had planned to achieve this by creating a text field in the Project entity called colorspace and setting the value to the show working colorspace. If the value was ‘aces’, a bit of python in the before_app_launch hook would set the env variable with the correct path.
I’ve spent a couple of days in the shotgun python API and googling and I have learned that I cannot extract the value, that I enter in the ui, via python as the value is not saved in the schema. Is this correct or am I missing somthing?
I had a look at adding a path in the project’s Pipeline Configuration page but couldn’t work out how to access this with python.
Any help is much appreciated.
Steve
Hi Steve!
You should be able to use the Shotgun API’s find() or find_one() method to get the value of your custom field from the Project entity. Adding a field to an entity definitely does store the value in your Shotgun database, so I’d be curious to see any documentation that implies otherwise.
I just added a custom field called colorspace to a test project and set its value to ocio; here’s how I got its value (note that Shotgun prepends sg_ to the system names of custom fields):
>  shotgun.find_one('Project', [['id', 'is', 135]], ['sg_colorspace'])
{'type': 'Project', 'id': 135, 'sg_colorspace': 'ocio'}
And if you want to get straight to the field value, you can do:
> shotgun.find_one('Project', [['id', 'is', 135]], ['sg_colorspace'])['sg_colorspace']
'ocio'
Once you have that value, you should be able to do your python magic to determine the path to point your environment to.
I hope that clears things up! Let me know if not!
Thanks Tannaz,
This does make things clear. I did think it odd that values entered in the ui wasn’t accessable via python. I think it came from a blog post and I, obviously, misunderstood something in the API docs.
Thanks again
:slight_smile:
