Set Upstream published files outside of tk-multi-publish2
I have some publish that happen outside of tk-multi-publish2 and I would like to set Upstream published file from python api. Unfortunately, I can’t find the field name for this column like I usually do for other datas.
What fields need to be set for this?
Kind regards,
Kevin
The field code is upstream_published_files. For fields you can’t configure you can jump over to the global fields page, and filter by the entity type you are looking for.
Perfect! Thank you very much.
