Rvlink with a script or command
Hi
like the topic
can I use rvlink with -pyeval or other command on the browser?
e.g.
rvlink:// -pyeval ‘import%20my_module;my_module.run(‘D:/file_path.json’)’
Hi Bon,
I think they locked a lot of that down awhile ago for security reasons. You can imagine how bad it would be if you could effectively run anything in python from a web browser… yikes
A reasonable alternative is to use -sendEvent <eventName> <payload>
Then an RV package that is already installed in RV can respond to external-<eventName> and the event.contents() will contain the payload you sent.
The -sendEvent can be encoded into an rvlink. If you want help figuring out how to encode payloads, check out running RV from the command-line with all the args you want and then adding -encodeURL, or if you want it to be even more resilliant and don’t care about readability, you can do -bakeURL which will base64 encode your rvlink.
-Kessler
externalweb-package-for-rv
I have referenced your topic, then it works.
Thanks a lot.
