RV Tablet Annotations are Leaving a dot at the end of every stroke
For some reason the annotations in the latest version of RV have started adding a little dot at the end of every stroke when pressure sensitivity is on. This dot is added to the undo queue. I have tested different wacom pens. I have tested A cintique 22" and a wacom intuos 4. I have also tested windows Ink On and Off. This is making annotations useless and we may have to transfer to sync sketch to annotate our work.
cintique
rvAnnote
undo
Oh wow! I just solved it. Disabling video Sync resolves the issue. That’s still a bit of an issue though as we need video sync on correct?
Separate issue that is somewhat related. For some reason I need to have windows ink activated to get pressure sensitivity in RV. This is causing there to be a mouse click triggered if I click once on the screen. When annotating this leaves a large dot where the click happened. When trying to draw fin details it treats this as a mouse click and I end up with a large dot. Is there a solution to this?
click
hey you guys, so pressure sensitivity is working for you? because I can only use my wacoms (yeah I tried different ones) for annotations when I turn it to mouse mode… this is a bit annoying because I have to switch it all the time…
and in other web-apps there is no problem drawing with my wacoms…
Only if I use windows ink in the wacom settings. With it off I can’t get pressure sensitivty. Is this a bug?
Hi! I just found the solution by checking/unchecking the “Use Windows Ink” in Wacom Tablet Properties.
Hope it helps.
