RV input sources named: sourceGroup000000_switchGroup
When I load a playlist into RV from SG in the web browser my versions appear as:
sourceGroup000001_switchGroup
etc.
in the inputs, which means I cannot sort them alphabetically. How can I fix this, so the inputs use the source filename or the version name from SG?
I found the solution to this issue after much trial and error:
in RV select the ShotGrid menu → Session Prefs → untick “Use Multiple Source Media Representations”
That worked for me, hope this helps someone out in future.
