REST API session_uuid not working?
Has anyone successfully been able to pass along a session_uuid using the REST api?
It is documented briefly here that you can pass along a session_uuid when getting an access token: ShotGrid REST API v1
However, I am trying to respond to a webhook using the rest API and despite authenticating with a session_uuid:
{'client_id': 'development', 'client_secret': ****, 'grant_type': 'client_credentials', 'session_uuid': '7673a744-a9a9-11ee-8153-0a58a9feac02'}
Updates aren’t refreshing live in the UI and I don’t see a session_uuid in the event log:
{'description': 'development 1.0 changed "Status" from "ip" to "fnl" on Task cmp',
  'event_type': 'Shotgun_Task_Change',
  'id': 5543040,
  'session_uuid': None,
  'type': 'EventLogEntry'}]
Has anyone gotten this working?
Hey @svfx, I realize this post is quite old, but curious if you were able to get this working? I’m running into the same problem exactly
Never got it working, we ended up switching to the Python API to respond to webhooks where setting a session_uuid works correctly.
I assume this is a bug or documentation issue, but I never bothered to reach out to Autodesk support about it. You could give it a shot.
