Hi there
Is there a way to query the current Shotgun context using python inside Houdini? I’d like to set parameter values according to the current shot/asset and have those values update if the scene is re-saved to a different context.
Regards
David
Hi @David_Schneider
To get the current context from a python script running inside Houdini, but not from a Toolkit app you would do something like:
import sgtk
# get the current Shotgun engine instance
# get the current engine context.
ctx = engine.context
I’ve not tested that directly in Houdini, but I believe it should work.
Works great! Thanks Philip.
