Connect shotgun API from inside DCC
Is there a convenience method to get the Shotgun API when you are inside a DCC launched from SG Desktop? I do not want to have to run:
sg = shotgun_api3.Shotgun(SITE_URL, SCRIPT_NAME, API_KEY)
…every time I wish to get an instance of sg. Say I launch Maya through the Desktop and jump into the Python script editor. Shotgun should already be connected and authenticated through the Desktop login. Is there a quick way to get sg where I can then run sg.find_one(...)?
Hey! Take a look at the code snippet in this post:
The engine object has a shotgun property, which is a handle to the Shotgun API, so you can get to it via sgtk.platform.current_engine().
Thanks @tannaz! I remember Stephen Chiu and Mark Thielen mentioning this when I was at WB, but we never used SG Desktop to launch DCCs, so I never looked into it.
