Hi there!
I’m seeing an issue where the File Open dialog is showing work and publish versions of the same name incorrectly. I would expect the publish and work files to be shown separately, even if they have the same file name (but different paths). The work and publish areas looks like this:
But the File Open dialog looks like this:
And if I just isolate the Working files through the tab at the top, it still shows me a published file:
And then, if I open the published file from the Working tab, it asks to work from the published file or work from the older working file. That’s fine, but then when I open the file and try to use File Save, it takes a couple of seconds to decide what version it should suggest as the next one, and eventually settles on v004 (whereas there is only v001 in the work area, so I would have expected v002).
The two path templates at play here look like this:
maya_asset_publish:
definition: '@asset_root/{Step}/source/maya/{Asset}_{Step}_{name}_v{version}.ma'
root_name: 'secondary'
maya_asset_work:
definition: '@asset_root/{Step}/{username}/maya/scenes/{Asset}_{Step}_{name}_v{version}.ma'
root_name: 'primary'
So I’m just wondering why the working files don’t show up as separate in the File Open dialog (they seem to be considered the same as the published file if the name matches) and also why the File Save dialog is considering the published files in it’s suggestion for the next version?
I hope this all makes sense. Let me know if there’s anything I can clarify. Also, apologies for all the messy redactions - NDAs and all that!
