Premult with OCIO
how can I premult an image with alpha in RV when using OCIO? The premult function in the menu only adjust the RVLinearize node but that’s not in use when OCIO is set up. Any other way to get there?
M
SOLVED: I found the premult node from the additionalNodes.gto, works fine.
