Notes created via python api don't appear in Task/entity feed
I’ve created a note via the python api but it only appears on my Tasks “Notes” tab, not in the “Activity” feed.
I’ve checked all the fields match other notes I’ve created directly from the web ui so I can’t see what else I can do to trigger the note to appear in the entities activity feed. Is this a but or unsupported feature?
Thanks for your help.
Patrick
I’ve raised this as an internal ticket now.
Have you ever found a solution to this problem? I am having the same exact issue.
No, not that I’m aware of.
Assuming the note is created by a Script User, is the checkbox on the script user “Create Event Log Entries” enabled?
The activity Feed shows event logs
