More than one field in Step collapsed view?
Was curious if this existed and if so how to enable?
I was hoping to set my Step collapsed view to two fields (name and status) instead of just the one. Please let me know if anyone knows if/how this is done.
Cheers
HI @Chris_Bennett
Thanks for writing in, hope you are well. Sadly it isn’t possible to have more than one field visible when a pipeline step is collapsed. Currently, it will use the left-most field to show when it is collapsed.
I can totally see a good use-case for this though, having the status field on its own can be confusing if you have a lot of tasks within a single step and you want to know what tasks they are.
One workaround might be to duplicate your existing page view, set the first view to show the pipeline step expanded with those 2 fields, and the 2nd view can be saved with the column showing all the other fields. This will allow you easily switch between them, though I understand this falls apart when you are constantly making updates to that page and having to update both views.
It would be great if you wouldn’t mind adding this to our public roadmap below
If you have any further questions don’t hesitate to give us a shout.
Andrew
