Libgcrypt.so.11 dependency vs RHEL 8 distributions
The 2023.07.006 version of the ShotGridCreate binary seems to have a dependency on two separate versions of libgcrypt.so : version 11 and version 20:
$ ldd ShotGridCreate  | grep libgcrypt
	libgcrypt.so.11 => not found
	libgcrypt.so.20 => /lib64/libgcrypt.so.20 (0x00007fdd6655f000)
libgcrypt.so.11 is the version that comes with CentOS 7.9, but is not available for RHEL 8 and derived distributions (Rocky Linux, Alma Linux…) where libgcrypt.so.20 is the default version.
Is there a separate installer than ShotGridCreate.rpm which supports RHEL 8/9 distributions, considering that CentOS 7is going end-of-life pretty soon and most studios are in the process of transitioning away from it? If not, is there a timeline for RHEL 8/9 support?
JF
@panisset Did you get this working? I’ve hit the same issue.
