Hello guys, I would like to setup LDAP authentication for my shotgun application. Could you help with the setup process ?
Thank you for contact us in community. The LDAP authentication is only available for local install client. Do you use hosted or local install?
Loney
Hey @mahesh197, if you are not hosting Shotgun locally, you may be interested in our SSO support. Note that SSO does require a Super Awesome support subscription though.
Hit us up here with any other questions!
Yes we installed locally.
May i know the YAML format for my LDAP configuration
I don’t know if you could access the article LDAP Integration. If you can’t access, you could create a ticket. We can grant you the access.
Loney
