Introducing shotgrid-js-sdk — a TypeScript SDK for ShotGrid / Flow Production Tracking
Hi everyone!
I’d like to share shotgrid-js-sdk, a community-built TypeScript SDK I’m developing for Autodesk Flow Production Tracking (ShotGrid / Shotgun).
If you’re building pipeline services, internal tools, or web applications with JavaScript or TypeScript, the goal is to make ShotGrid integration more convenient—with typed queries, editor autocomplete, and less repetitive REST API code.
Some highlights:
  • Typed fluent queries with return types inferred from selected fields.
  • Familiar Python-style methods, including find(), findOne(), create(), and update().
  • OAuth token management, including token refresh.
  • Batch operations, summaries, schema reads, and iteration over large result sets.
  • Extensible entity types for your studio’s custom fields.
  • ESM and CommonJS support, with TypeScript declarations.
Here’s a small example of the fluent API in the development branch, using an initialized server-side client:
const assets = await sg
  .query('Asset')
  .where('project', 'is', { type: 'Project', id: 123 })
  .select('code', 'sg_status_list')
  .orderBy('code')
  .limit(50)
  .all()
If you’re coming from the Python SDK, you can also use familiar calls:
const asset = await sg.findOne(
  'Asset',
  [['code', 'is', 'Hero']],
  ['code', 'project'],
The repository includes examples for connecting a server-side ShotGrid client to React or Vue applications through your own API, including an oRPC + TanStack Query integration. These integrations are optional—the SDK itself doesn’t require those frameworks.
This is an independent community project and is still evolving. The development branch introduces a new API that isn’t yet included in the published npm release. Full Python SDK parity and file uploads/downloads are outside the current high-level API. Testing currently uses protocol fixtures, so feedback from real ShotGrid environments would be particularly valuable.
I’d love to hear from other ShotGrid developers: what would make a JavaScript/TypeScript SDK useful in your workflow? Suggestions about API design, missing features, and integration issues are welcome, as are issues and PRs.
GitHub — shotgrid-js-sdk
Thanks for taking a look!
This is great!
Will be sure to check it out!
Thanks for the suggestions! To clarify the browser use case: would you like to keep using the SDK’s typed query API in the browser, while routing requests through your studio API using your existing application session, with ShotGrid authentication handled by the backend?
Does your studio API preserve ShotGrid’s request/response format, or expose its own endpoints? A small example would help clarify whether custom HTTP client configuration is enough or a separate transport adapter would be useful.
I’m also planning a documentation site with more examples, including custom schema typing and raw requests. Let’s open an issue to discuss these use cases and the API design first—it would be a good place to collect examples and continue the discussion.
