I’m looking for confirmation that you can change sg_status_list using the Shotgun API.
I’m importing a project snapshot from another project. They’re both using same Project Template but some field values e.g. Task.sg_status_list.
I’m using the following code:
sg_properties:dict = {
'valid_values': list(valid_values),
try:
self._sg.schema_field_update('Task', 'sg_status_list', sg_properties, self._sg_project)
except:
self.logger.error(f"failed to update schema field 'sg_status_list' with values {valid_values}")
I get the following error:
tank_vendor.shotgun_api3.shotgun.Fault: API schema_field_update() invalid/missing 'status_list' string
Can I even change or add to the status_list values using the Shotgun API?
Have you been able to successfully do this?
