Edit: I’ve modified the original post to include the below error.
I’ll note that the following error can also be a symptom of the same issue:
ERROR: Database concurrency problems: The path
'Z:\projects\SpaceRocks\shots\ABC_0059' is already associated with
Shotgun entity {'type': 'Shot', 'id': 1809, 'name': 'ABC_0059'}. Please re-run
folder creation to try again.
I’m not sure how the db ends up in this state, but above “How To Fix” steps, save for the first one about roots.yml
, should also apply to this error.
