Hey,
I am sure i am missing something super obvious but I am trying to add a note to a shotgun sequence (ideally I could do this for a shot or asset or anything). I’m not sure what the best way to do this is via the python api.
To note, this is being done through a script authentication not a user.
Hi @thebeardedberry,
Check out the shotgun methods page (http://developer.shotgunsoftware.com/python-api/reference.html#shotgun-methods) It’s always my first stop for using the Python API.
As for your question, I would use a create method to create a note and then add the Sequence into the Links field, here is an example;
data = {
"project": {"type": "Project", "id": 87},
"note_links": [{"type": "Sequence", "id": 45}],
"subject": "This is the Subject",
"content": "This is the Body Text",
"user": {"type": "HumanUser", "id": 87},
"addressings_to": [{"type": "HumanUser", "id": 92}]
sg.create("Note", data)
Just replace the relevant id’s and its should work for you.
-David
