How can I launch the MultiPublish2 from a custom setting?
I’m working in Maya and I need to launch the publisher UI from a context other than the item other than the Shotgun menu.
Initially it would just be good to launch it from the script editor - I can get an instance of the app using:
publish_app = engine.apps.get("tk-multipublish2")
but I can’t see where I go from there. I see there’s an engine.show_dialog() but I need to provide the QWidget dialog class and I can’t see how I would have access to that?
Any pointers? I feel like I’m either missing something basic, or this is much more complicated than I’m assuming.
Cheers
Hi @joejf
You can’t launch an app from a context different from the engine’s current context. You would have to change the engine’s current context.
However, just because the publisher is launched in a certain context, doesn’t mean it needs to gather from or publish to the same context. The publish plugins are customizable so you could modify it to act in a different context.
Hi @philip.scadding,
I don’t mean to change the engine’s context, but I would to trigger the launch of the Publisher from somewhere other than the Shotgun menu (e.g. from a python call in the script editor, or from a custom plugin window). Is that not possible?
Cheers
Ah I see, so this might be what you are looking for:
Thanks, that seems to be just what I’m after!
