Help with Linking Notes to Playlist in Screening Room
How can I get the links field for notes to include the current playlist when reviewing in screening room?
Right now my supervisor reviews and submits his notes in screening room; however, the playlist isn’t included by default in the links field, so the note is only attached to the version and the shot.
It makes it a little complicated to find all the notes once he’s finished reviewing remotely.
thanks
Hi KGreene!
Welcome to the community :).
Are you using Screening Room for RV, or on the web? I did a quick test in the web player, and when I’m browsed to a Playlist, all Notes I create for Versions I play there are linked to the Version, entity the Version is linked to, and the Playlist.
If you could send a screenshot of the context in which your supervisor is reviewing, I can either try to reproduce or advise on how to remedy.
Hi Brandon - thank you for the help. We are using screening room for the web - I’ve attached a screen shot of the links section when I start to write a new note. Hope that helps - I don’t want to inadvertently include images from my show which is under NDA.
21%20PM
Very curious. Would you be able to send me a private message with a link to the Playlist where you’re experiencing this? That way I can log in and investigate.
My project is noticing a similar behavior to what KGreene described. Would it be possible to share the results of Brandon’s investigation?
I have this same issue, but with ShotGrid create. I am sending reviewers to review via the Playlist view - however they note only links to the Version, not the playlist as well. Any tips?
If a solution was found to this it could we add it here?. We are encountering this odd behaviour ourselves. Screening room in the browser links to the playlist if launched via the media page. If launched from a playlists page, or using Screening Room in RV it does not link to the Playlist for the note. It always links to Shot and Version. Just not the Playlist you send to screening room.
