Finalising migration - will API script entities remain functional?
Hi all,
I am about to pull the plug and finalise my migration to Autodesk identiy only and just need a sanity check:
API Scripts remain funcional after this, right? I only saw a note about personal tokens if you use personal accounts to connect with the api. I am not doing that, just using script entities. Safe to jump or do I need to do anything with those scripts first?
frank
Hi @frank
No change for authentication with Script Name / API Keys.
But one change in behaviour : they will not be able to flip a HumanUser’s sg_status_list from whatever state to act (or create a new HumanUser that is active)
Relevant docs: Help
Hoping it helps,
-Patrick
great, thanks @patrick-hubert-adsk
