I tested that on my side and it worked as expected, so I don’t think there is a problem with your filters there unless your task status is not actually ‘fin’.
Could you check to see if the loader is actually using your settings?
If not perhaps one of the following is true:
- Your not using the config you are modifying.
- The settings block you are modifying for the loader is not being used in your current environment.
Phil
