Hello. Is there any way to filter EventLogEntries by fields inside metadata within the query? I found an example that does filter events my metadata but that was done after the query, can I use for example the “old_value” field of the metadata to filter events inside the query?
Hi @xizted,
Tried to figure this one out for u but any API call returns following error code:
Fault: API read() EventLogEntry.meta’s ‘serializable’ data type cannot be used in a filter
However if your goal is to filter on “old_value” you could use a combination of “Status” and “From” in the summary field for your query since it also contains this info.
I do think that this query would be very heavy to process as you are scanning through thousands of entries.
