File Open Tool - About display extension of pipeline step items
Hello
I have set up the pipeline steps used by the Shotgun project.
(asset_active_step.PNG, tracking_settings.PNG)
However, the steps in the FileOpen tool show all the steps.
(file_open.PNG)
I want to display only the steps set in the Shotgun project, or limit the steps displayed in the config etc.(file_open_goal.PNG)
(The attached image file_open_goal.PNG is realized by directly editing the source code of the application)
asset_active_step
Hi @katayama
Yes unfortunately that is the case right now. It is gathering the steps with no consideration for the project. I see you put a support ticket in and a feature request was already submitted via the roadmap.
I don’t unfortunately have any other suggestions currently. The fix should be fairly straight forward if you want to take over and modify the app itself:
I think you would just need to add a project condition filter there, though I’ve not tested.
Best
Phil
Hi Philip.
Thank you for your response.
I understand.
Looking forward to future updates!
Thank you.
