I would like to playback .exr’s from the comp team in Resolve for dailies. Using a shotgrid dailies list or playlist. Somebody must have requested this before? Thanks in advance.
I would like to do that too. Have you ever found if a solution has already been created? Thanks!
Hi @patrickwolf
Have not tested this in real life, but one idea would be to load the playlist in screening room for RV and export an otio file from there. Then import the otio file into resolve. Pretty sure the screening room in RV cannot be scripted but maybe the other parts can?! Anyway hope that helps a bit. ![]()
Fabian
Agreed, otio is the way to go. It natively supports a number of formats for import/export.
Thank you I’ll consider it as we get closer to the feature!
