Can i able to delete my project with assets and shots? How?
Fully deleting projects is a two step process. Projects are archived first (hides them from users and search options) then if you choose, you can delete them.
Go to the bottom of the Projects menu/All Projects.
Select the project you want to archive/delete, more menu (or r-click), archive project. Or you can check the archive box.
If you select an archived project, that menu option will change to Send selected project to trash
It works, thanks a lot.
