Control the playback/RAM cache settings?
Hiya,
is there a way to control how much RAM SG Create uses to cache a frame sequence and what behavior like in RV? (Look ahead etc.)
Not sure if I’m seeing it correctly but I don’t think it’s using more than 50% of my RAM which makes it chug on longer shots.
Hi Ricardo,
The default cache size for the player is 20% of the available RAM.
You can use the following environment variable to override the default value (to 4096 MB in this example):
setenv SGC_PREF_READER_CACHE_MAX_SIZE_IN_MB 4096
I hope this helps.
Eric
is this documented somewhere? :slight_smile:
