Feature Request
It would be nice to add support of Multi-Entity Fields on ConnectionEntities.
Example
We are using a CustomEntity called “Delivery Config”.
We want to link “Delivery Configs” on Versions in Playlists.
At the moment, I’m forced to create a Multi-Entity Version Field.
This is problematic because it means that field will be shared across Playlists (Since it’s on the Version, and not the Version Instance).
I can only create an “Entity” Field on ConnectionEntities, but that means I can only link 1 Entity at the time. It doesn’t fulfill our need
