Hello, is there a way to get a list of Client users that a Playlist is shared with using the Shotgun REST API?
You can probably use the search or summarize endpoints.
If you were using the search endpoint, you would POST to:
/entity/PlaylistShare/_search
your filters would be: [["user", "type_is", "ClientUser"]]
and the fields you want to get are [user.ClientUser.name].
You can then make a set out of your list of results.
Summarize would be roughly the same, your filters are the same
your summary_fields would be [{'field':'user.ClientUser.name', 'type':'count'}]
and your grouping would be [{'field': 'user.ClientUser.name', 'type': 'exact', 'direction': 'asc'}]
Summarize should be a faster query and has the advantage of telling you how many playlists were shared with a ClientUser.
