We use fox renderfarm extensively for renders than depending on local renders. How is it possible to submit render from any dcc say maya for eg. and this should get rendered on the fox renderfarm. ?
Your question seems two fold, you want to submit renders from Maya to Fox renderfarm which is independent to ShotGrid integration.
okay. Then i can independently register/ add entries to shotgrid where applicable. Correct.
Yes you can use the API and the publisher and all other things available to you to register the output and push info to shotgrid.
Maybe Fox Renderfarm can do webhooks or event scripts to automate things.
