Hi
Is there a way to change a base project folder name after creating it using Shotgun Launcher > Advanced Project Setup?
I did not create any assets etc, I just want to change the top project folder name.
Thanks.
Hi
Thanks.
yes, you can change the tank_name field on the project.
However you may run into some path cache issues but thats a start.
(obviously, don;t try this on running projects as they will break)
