Hi
What is the best practice/recommended setup/workflow, when you are turned over Plate in .exr files ? Is there a step by step recommended start up guide.
Something like this ?
For example
- Manually put .exr files on the server into sequences and shots folders (somewhere outside shotgun).
- Open nuke, and write .exr files via shotgun write node, so it write into the correct shot folder in shotgun directory.
- Publish .exr, so it generate a streamable media on shotgun site.
Another question
How do you create sequence and shots, and enter shot information, as frame range, handles ? Do I have to do it manually on each one ? isn’t there some thing like EDL import or something ? we can just automate this process ?
In short, is there a way to auto-populate sequences and shots, then associate the plates with it ?
Thanks a lot
