API Two-Factor Authentication
Hi @Jase_Lindgren,
My answer assumes that you are using Shotgun’s own two-factor authentication support, and that you are not using SSO for Shotgun Authentication.
In short, 2FA will only impacts connections initiated using a username/password pairs. It will not impact connections initiated with ScriptName/APIKey. From what you describe of your environment, your existing Python API-using scripts will continue to work as before.
For connections initiated with a username/password, that user will need to provide a code from the Google Authenticator app or Duo Mobile App using their smartphones. The same way they’ll need to do when authenticating into Shotgun once 2FA is turned on.
That code is what needs to be passed on as the auth_token for your call to get the OAuth2 access token. I believe that you will need to modify the authentication page of your web application to also ask for the user’s 2FA code.
I would suggest that you do your auth in 2 steps, the way shotgun does it. First you ask for the username and password. If you get HTTP status of 400, and an error code 106 it means a 2FA token is expected, so then you can show a second page that ask the user for that code. Once you have the user’s code, you modify your API call to Shotgun to include it. This way you can publish your changes ahead of your Shotgun server switching to 2FA.
Example of an API call that fails due to a missing 2FA code:
curl -X POST https://yoursite.shotgunstudio.com/api/v1/auth/access_token \
-H 'Content-Type: application/x-www-form-urlencoded' \
-H 'Accept: application/json' \
-d 'username=a_username&password=a_password&grant_type=password'
    "errors": [
            "code": 106,
            "detail": null,
            "id": "243dd3f5f1875cecc88d52e0eff8c72c",
            "meta": null,
            "source": {
                "auth_token": "missing for 2FA login"
            "status": 400,
            "title": "Missing argument for 2FA login"
(I took the liberty of pretty-printing the resulting json payload)
You would then modify your call, adding the 6-number 2FA code:
-d 'username=a_username&password=a_password&auth_token=123456&grant_type=password'
At this point, assuming the credentials are correct, you would get the expected payload with the Bearer token.
    "token_type": "Bearer",
    "access_token": "an_access_token",
    "expires_in": 3600,
    "refresh_token": "a_refresh_token"
For others looking at this thread, the relevant documentation pages are:
Hoping you’ll find my answer useful,
-Patrick
