So I am very new to Shotgrid and I have managed to make some changes so I can render and publish from Nuke without any issues. But since I have not dived deep to the hooks system I have a very basic understanding of how they work and where they need to be defined when I customize some apps for our workflow. But I stumbled upon a serious issue with ACES. It seems I cannot find a solution to fix the errors Publisher and Quickreview are throwing when I work in ACES. Only way to mitigate this, is basically to do everything manually which defeats the purpose.
I tried adding the tk-multi-reviewsubmission/render_media.py to the hooks folder, also changing it’s hook to the tk-multi-reviewsubmisson.yml (render_media_hook: ‘{config}/tk-multi-reviewsubmission/render_media.py:{config}/tk-multi-reviewsubmission/render_media.py’
But I have no way of checking if that is loaded and accepted or it falls back to the original app
Now I am also trying to change the tk-nuke-quickreview/settings.py to hardcode an sRGB colorspace just to see if that works, but I have no idea where to define the hook afterwards. I would guess tk-nuke.yml but what hook variable do I use?
In the tk-multisubmission it was “render_media_hook”. Where do I find the hook var?
Any help would be much appreciated
