8.84 Release Notes
Release date: March 23rd, 2026 ET
We released the following updates since 8.83:
Improvements:
Subscription Manager:
  • Improved performance of the Subscriptions Manager page when a large number of Human Users are present. [SG-36689]
Bug Fix:
Data Importer:
  • Fixed an issue where the “Project” column was not recognized in non-English user interfaces. [SG-42097]
API:
  • Fixed an issue where the python API::Version returned the value of the preceding REST API request. [SG-42566]
  • Fixed an issue where exporting a layout via the API without specifying a layout name returned the first layout instead of the updated default layout. [SG-41725]
Webhooks:
  • Fixed an issue where webhook emails displayed incorrect site URL. [SG-42174]
Micellaneous:
  • Fixed an issue where the email suppression list banner did not appear. [SG-42063]
  • Fixed an issue where search options did not persist when changing or reloading a page. [SG-41767]
  • Fixed a regression where changes could not be saved in the entity creation dialog. [SG-41653]
  • Fixed an issue where changes could not be saved in the entity creation dialog after creating a web Widget with the pre-filled form URL. [SG-41578]
v8.84.0.8661
Improvements:
Webhooks:
  • Added email notifications for administrators when webhooks transition to a failed state, enabling faster remediation and reduced production downtime. Previously, notifications were only sent when webhooks became unstable. [SG-42275]
Miscellaneous:
  • Removed threaded entities (e.g., Delivery, Ticket, and custom entities) from the Global Follow Settings page, as they do not support following and could cause confusion. [SG-5927]
Bug Fix:
Gantt:
  • Fixed an issue where tooltips did not appear when hovering over tasks in the bottom-right area of the Gantt chart. Tooltips now appear to the top-left of the cursor. [SG-5699]
API data export:
  • Fixed an issue where users could see column headers in CSV exports via the API even if they did not have access to those columns. Column permissions are now respected, and restricted columns are excluded from the export. [SG-42220]
Data Importer:
  • Fixed an issue where bulk import overwrote multi-entity field values instead of appending new entities. [SG-42562]
  • Fixed a regression where the Bulk Import preview step failed when using the Project column in non-English user interfaces. [SG-42404]
Miscellaneous:
  • Fixed an issue where the Global Follow Settings page did not load when a follow field had been deleted. [SG-38460]
v8.84.0.8761 (build d6d4fc8942)
Improvements:
Miscellaneous:
  • Improved field identification after renaming by displaying the full name on hover and adding a visual indicator for renamed fields. [SG-39634]
Bug Fix:
Site Activity Monitor:
  • Fixed a regression where the “Email Notification – Delivery by Type” graph did not load. [SG-42406]
  • Fixed a regression where the “Email Notification – Delay Widget” graph did not load. [SG-42405]
Data Importer:
  • Fixed an issue where Add/Remove actions were not applied when more than 25 entities were selected. [SG-42328]
Global Entity Page:
  • Fixed an issue where all Status values across projects were displayed on a Global entity page instead of only project-specific values. It was also possible to assign a Task a Status that was not valid for its project. [SG-42164]
Tasks:
  • Fixed an issue where dragging a Task’s start or end date in the Gantt chart (dark mode) did not display the pop-up text. [SG-35586]
