Release date: July 16, 2024 ET
We released the following updates since 8.64:
Improvements:
Site Preferences
- Added a preference in the Security section which forces a user to log in to their Autodesk account after a logout, disregarding the user session expiration preference. [SG-34872]
Integration
- For sites on non-tflex subscription: Usage licence are now automatically renewed. The idleness modal dialog that appears every 24 hours should no longer be visible. [SG-34429]
Bug fixes:
Account
- Fixed an issue where not all sites would be displayed on Flow Production Tracking Home page. [SG-35006]
- Fixed a regression with LDAP authentication on local installs. [SG-35505]
Entity Detail
- Reducing the payload returned by cross-project assets. [SG-33313]
- Fixed an issue where a query field on the pipeline task would produce not correct data when the task id is the same as parent entity id. [SG-34615]
Filter Panel
- Fixed an issue where notes with draft notes would be filtered out by a disabled filter. [SG-35059]
Infrastructure
- Fixed an issue where multiple “launch_darkly” warnings would be displayed in application logs on local installs. [SG-34723]
Integration - Licensing
- User activation/deactivation is less likely to time out on the people page. [SG-35714]
Pages Menu
- Fixed a visual issue when performing right click on an entity’s task in a pivot table column. [SG-11001]
People
- Fixed a regression where in some cases a user could not be activate on the People page if a user has already existed on manage.autodesk.com. [SG-35645]
Python API
- Fixed an issue where unsupported entity types could be added to a single-entity field via API. [SG-33828]
Queries
- Fixed an issue where no value will be displayed, empty instead of zero, when summarizing a query field by
Status > Percentage Roundedand status value isn/a. [SG-34927]
Review Notes App
- Reverted layout changes on Review Notes App’s Summary Emails for Versions where Task link is empty, removing “No context provided” legend above Note. [SG-35647]
