Release date: August 3 , 2021
We released the following updates since 8.27:
Improvements
New Quick Search filter field dropdown. Simpler and intuitive search field selection with multi-field search support. [SG-21043]
Performing entities import from a global entity page is now also be possible using Project ID field. [SG-22063]
In the case where a user has permission to update the field but not permission to see everything that is in the field, apply permissions fully on an update to the returned contents of a multi-entity field. [SG-23056]
FFmpeg 4.2.1 is now used by default without having to change transcoding profile manually. [SG-11750]
Fixed bugs
- When a permission role doesn’t have access to edit Global formatting rules, they are no longer able to access and change a set up rule on an entity’s page [SG-22978]
- Webhooks no longer requires you to set up personal access token [SG-23174]
- Fixed an issue when some statuses could remain visible on an entity creation form, even though they were hidden in a project tracking settings [SG-15133]
- In the Quick Search filter, for cases when there are no visible columns (Details/Thumbnail view), a default group of fields to search has been added. [SG-23372]
- Vendor users no longer have to be member of at least one group in order to access their account settings. [SG-19695]
- Fixed an issue with a filter button on My Tasks page being unresponsive. [SG-23229]
