Hi everyone
So the tk-multi-loader2
app does not make use of templates to valid the paths, unlike the tk-multi-workfiles2
app.
Instead it simply looks for PublishedFile
entities that are linked to the relevant entity selected in UI, and that the PublishedFileType
of the published files matches the ones configured in the loader settings.
The get_publish_path
method comes from the base Hook class. Which when given a PublishedFile
entity dictionary, it will return a path appropriate to the operating system.
So if the alembic file is not showing up, then it’s most likely that one of the following is true:
- It doesn’t have a path for your operating system
- The loader is not configured with actions for that
PublishedFileType
- The selected entity in the UI is not properly associated with that
PublishedFile
entity. - There are additional filters being applied, either via the
publish_filters
setting, or via thefilter_publishes_hook
Best
Phil
