Followed the Quick Guide Step to Setup The Shotgun Server https://developer.shotgunsoftware.com/sg-jira-bridge/quickstart.html#quick-start
After setting up both the server, when I navigate to Shotgun Webpage and create a task it wont sync. Unchecking and checking the SYNC_IN_JIRA does not produce any logs in either of the server.
In Starting Up Section, I was successfully able to Match Shotgun User and also Start the SG Jira Bridge. Though when I start ShotgunEvents I get the following Error/Warning
Critical:engine: Did not find a registeredCallbacks function in plugin at {path to Jira triggers}/triggers
Not sure if this is the cause of the syncing issue but I have updated the Environment Variable and also tried hardcoding the SGDAEMON_SGJIRA_NAME
and SGDAEMON_SGJIRA_KEY.
Any help resolving the issue will be appreciated.
MBK
