Hello Shotgun Community!
We are using tk-multi-setframerange. We would like to automatically trigger it when creating a new Maya file for exemple.
From what I’ve seen so far tk-multi-workfiles2 has the following hook setting:
tk-multi-workfiles documentation
hook_scene_operation
Type: hook
Default Value: {self}/scene_operation_{engine_name}.py
Description: All the application specific scene operations (open, save etc) that the app needs to carry out are collected together in this hook.
So within this hook_scene_operation, how to properly call tk-multi-setframrange?
Kevin
So for a new scene, you would want to put your logic in the elif operation == "reset": block of the hook.
To run the app, you have two choices
Call the registered command
engine = self.parent.engine
# Optional, but just so we can see what commands are registered.
self.logger.debug(engine.commands.keys())
app_command = engine.commands.get("Sync Frame Range with Shotgun")
if app_command:
# now run the command, which in this case will launch the Sync Frame Range app.
app_command["callback"]()
app = engine.apps.get("tk-multi-setframerange")
framerange = app.get_current_frame_range()
Wonderful Philip. Calling the registered command is exactly what I was looking for.
Thank you for your help.
Kevin
