Hi all,
I want to change the behavior of publisher in Maya when publishing rendered image sequences, in order to have a Work Template and a Publish Template for the images, to eventually copy the images from work directory, for example.
Currently, if I add a custom plugin for rendered images, I can set the Publish Template for it, but in the publisher UI, I’ll see both my custom plugin and the base publisher plugin that automatically detects image sequences.
I would be grateful if you could help me solve this problem.
Thank you,
Mo.
