Studio with remote workers
Hi @Maxwell,
Still think you probably need to clarify a bit more what aspect of remote workflow you are trying to set up here. Is there any specific remote collaboration you get blocked?
With Shotgun as a cloud-based platform, remote workers can access your Shotgun site the same as they are in the studio. All the functionalities on Shotgun webapp should work the same while users switched to work remotely.
It’s the Shotgun toolkit configure you probably need to modify when switching from in-house production to remote one. You could refer to the dochere to see how to set up a distributed pipeline configure.
You have set up a centralized configure, you could follow the post below to turn from a centralized configure to a distributed one.
If you would like furthermore to share published files with a cloud storage, then Philip has mentioned the following post previously.
It’s all generic guide, and let us know what’s blocked on your side so that we could better direct you.
