Shotgun Jira Bridge Issue
Hello!
I’m back again! (I’m sure you’ve missed me! :wink: )
@kporangehat, I have a constraint to make the webapp and the ShotgunEventDeamon work in a separated server and not on my localhost.
So I dug a bit in the issue of not connecting, and something interesting emerged of this.
The socket function does not work. I’ve tried it even on the port I am 100% sure it works: the Jira port 8080.
I’ve installed in an AWS EC2 instance the webapp (the whole sg_jira_bridge with the venv) and correctly set up the security groups to allow port 9090.
It is successfully connecting to both shotgun site and Jira server.
But the daemon which is still located in my local server, is outputing this traceback repeatedly :
ConnectionError: HTTPConnectionPool(host='AWS_IP_ADDRESS', port=9090): Max retries exceeded with url: /sg2jira/default/Task/5803 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f37c535f610>: Failed to establish a new connection: [Errno 111] Connection refused',))
so what I’ve done is to try to look at the opened port in the EC2 instance, and I’ve found that:
sudo lsof -i -P -n | grep LISTEN
rpcbind   2670      rpc    8u  IPv4  16437      0t0  TCP *:111 (LISTEN)
rpcbind   2670      rpc   11u  IPv6  16440      0t0  TCP *:111 (LISTEN)
master    3121     root   13u  IPv4  18620      0t0  TCP 127.0.0.1:25 (LISTEN)
sshd      3286     root    3u  IPv4  19900      0t0  TCP *:22 (LISTEN)
sshd      3286     root    4u  IPv6  19902      0t0  TCP *:22 (LISTEN)
httpd     3390     root    4u  IPv6  21580      0t0  TCP *:80 (LISTEN)
httpd     3391   apache    4u  IPv6  21580      0t0  TCP *:80 (LISTEN)
httpd     3392   apache    4u  IPv6  21580      0t0  TCP *:80 (LISTEN)
httpd     3393   apache    4u  IPv6  21580      0t0  TCP *:80 (LISTEN)
httpd     3394   apache    4u  IPv6  21580      0t0  TCP *:80 (LISTEN)
httpd     3395   apache    4u  IPv6  21580      0t0  TCP *:80 (LISTEN)
python    3458 ec2-user    3u  IPv4  21920      0t0  TCP 127.0.0.1:9090 (LISTEN)
node     12329 ec2-user   18u  IPv4  29552      0t0  TCP 127.0.0.1:40447 (LISTEN)
httpd    12560   apache    4u  IPv6  21580      0t0  TCP *:80 (LISTEN)
httpd    12566   apache    4u  IPv6  21580      0t0  TCP *:80 (LISTEN)
httpd    12567   apache    4u  IPv6  21580      0t0  TCP *:80 (LISTEN)
I’ve noticed that the webapp is outputing 127.0.0.1:9090 and almost all the other ones *:80.
So I’ve made a little test on my EC2 instance.
I’ve just created a very simple flask app with 4 tests:
The first one was successful (it outputted correctly the hello world! text in the browser):
from flask import Flask
app = Flask(__name__)
@app.route('/')
def hello_world():
    return 'Hello, World!'
if __name__ == "__main__":
    app.run(host="0.0.0.0", port=5000)
The second test returned an unsuccessful code with a ERR_CONNECTION_REFUSED:
@app.route('/')
def hello_world():
    app.run(host="127.0.0.1", port=5000)
]Third one was successful:
@app.route('/')
def hello_world():
    app.run(host="0.0.0.0", port=9090)
And last one was unsuccessful with a ERR_CONNECTION_REFUSED:
@app.route('/')
def hello_world():
    app.run(host="127.0.0.1", port=9090)
Obviously, the only thing I’ve changed is the host value from 127.0.0.1 to 0.0.0.0.
I’ve tried very briefly to dig into the webapp.py and settings.py to find the host and changing it to 0.0.0.0 but I haven’t found it.
Is there any way to change the webapp host? At least we could try this thing to see if it is connecting?
Thanks a lot for your support! :slight_smile:
Geoff
Nice sleuthing Geoff.
Could this be what you’re looking for?
Docs for BaseHTTPServer:
https://docs.python.org/2/library/basehttpserver.html
Looks like you could replace "localhost" for '' and get it connected to all interfaces.
OMG!
How stupid I am! I’ve looked only for 127.0.0.1, Such a rookie mistake!
Again Patrick you’ve saved me! :wink:
Well, This was the last post on this one because it has been solved!
Now my Shotgun/jira bridge is working perfectly and it is a total success!
I really want to thank you all for your precious help.
A Massive special thank for Patrick, you are amazing!
see you all on the next issue! :wink:
Geoff
Awesome! I’m stoked we all got it working.
Have fun with Jira :heart: :shotgun: !
