Shotgun Daemon Events
Greetings Everyone,
Query : Need to register plugins on project basis. This way we can give production freedom to select which events they want per project. If this is possible then we can give production a tool where they can select the events in a UI.
Regards,
Pushpendra
You’re likely better off exploring webhooks in this case since they are able to be created and edited via the rest api.
But sounds like a lot of development, not sure you can (re)use much of the event daemon itself.
Thanks Ricardo,
Will definitely look into webhooks…
