File “C:\Program Files\Shotgun\Resources\Desktop\Python\bundle_cache\app_store\tk-multi-publish2\v2.6.4\python\tk_multi_publish2\api\plugins\publish_plugin_instance.py”, line 308, in _handle_plugin_error
yield
File “C:\Program Files\Shotgun\Resources\Desktop\Python\bundle_cache\app_store\tk-multi-publish2\v2.6.4\python\tk_multi_publish2\api\plugins\publish_plugin_instance.py”, line 180, in run_validate
status = self._hook_instance.validate(settings, item)
File “C:\Users\sreyeeshgarimella\AppData\Roaming\Shotgun\bundle_cache\sg\kavaleer.shotgrid.autodesk.com\v5273\hooks\tk-multi-publish2\standalone\upload_version.py”, line 29, in validate
raise Exception(error_msg)
Exception: Can not find episode with code 051 on Shotgrid.
Please make an episode in Shotgrid for this code, following the naming conventions:
###_Episode_Name.
I have the naming here has 101_EpisodeFoo the naming convention FOO_101_BG_SC051_v01.psd Episode exists on shotgrid. I’m wondering why would I be getting that error if the Episode name is there on shotgrid.
It seems like your publish app has been modified through hooks so I would first contact your Pipeline Developer/team as its not really something we can help you with here given the current information.
Thank you for the response. I am able to upload other episodes in this naming convention like the following : FOO_101_020.mp4 or eve FOO_101_BG_020.psd So the weird part is it takes in some of the shots into the publish but not all the shots. The naming convention is fine
