Query the bootstrap engine
Hay guys how will i go about querying the Boot strap engine i started new topic because cant find eni thing on this
So what i want two do is query the bootstrap engine of shotgun and if it isent there start it up from there
Hello – Can you give a little more information about what you’re trying to achieve or the context around it? Thanks!
Nvm i figured out how im gone check if the bootstrap engine of shotgun is running or not
I know you’ve found a solution, but for anyone else who comes across this thread, the way to check for an engine would be:
import sgtk
# This will return None if an engine is not running.
if engine is not None:
