Is it possible to query items using filters which test against partial similarity?
(in python)
for example some entities ‘Objects’ have field tags
object_1 -tags: ['square', 'metal']
object_2 -tags: ['circle' ,'rubber']
object_3 -tags: ['round','liquid']
object_4 -tags:[]
is it possible to create query which would found ‘Objects’ with at least one tag from
['metal','round']
in a single step ?
So that it would return
object_1 and object_3
Fabian
June 10, 2022, 4:40pm
#2
Hi @tweekazoid
It is possible with
Complex filters . Unfortunately I do not have the time to create you a code example but I hope that brings you in the right direction.
Cheers Fabian
That should help,
I will try that, but it looks like the exact thing I was after.
ok,
I;ve tried that. And it did the job
# returns doubly excluded items
r = sg.find( element ,
# filter 1 by date
['updated_at', 'less_than', datetime.datetime(2022, 7, 14, 12, 38, 22, 947614, tzinfo=datetime.timezone.utc)],
# filter 2 by assigned tag
{'filter_operator': 'any',
'filters': [['tags', 'name_contains', 'something'],
['tags', 'name_contains', 'another_thing']]}
filter_operator='all'
